Network Management
mobility controller setup
I am trying to setup and access the aruba controller 7005. Can anyone help me with the same. Whats the default ip of the controller?
Also, i do not have a console cable around.
Re: mobility controller setup
Have you seen the quickstart guide here?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=26228
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Hey !!! Thanks for the reply.
I have connected the controller to the laptop and set a static IP of 172.16.0.5 in order to access the controllet to its default IP of 172.16.0.254. Still i am unable to access it from my browser. Can you help me out?
If this is a new controller, those instructions will work.  If it is NOT a new controller, it might have a different ip address and you would need a console cable.
