The certifcates have always generated the question to be trusted on Iphones, but not on the windows laptops.
> do you use this for the Captive Portal, GUI or device authentication?
I don't undertstand the question, if my iphone/windows user log's on to the wifi they get a question to trust the connection
How can i check whether my certifcate is properly installed, and does anybody now this is a known issue with comodo?
Kind Regards
Gerard
