ZTP Process
1.The switch boots up with the factory default configuration
2. The switch sends out a DHCP discovery from the primary VLAN interface.
Switch would expect a DHCP option 60 with value “ArubaInstantAP” along with DHCP option 43 to parse Airwave details
3. After the Airwave details are verified and configured, the switch initiates the HTTPS connection to the Airwave server.
4. After a successful registration, Airwave can monitor, configure, and troubleshoot the switches.
5. If the DHCP options are not configured for Airwave, the switch is left in its default state for manual configuration.
It should be noted that if the ZTP device is the first discovered device in the newly created group and folder. Then it will show under the new devices list which we need to move into the desired group/folder
From the second ZTP device onwards for the same group and folder as the first device, it will automatically move into the corresponding group and folder.
