Norsk Forum
Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Occasional Contributor I
Differences between LLDP-MAD and VLAN-MAD
What is the use of configuring VLAN-MAD and LLDP-MAD within a virutal chassis?
Highlighted
MVP Guru
Re: Differences between LLDP-MAD and VLAN-MAD
Please check this Airheads post, and the Switch Management and Configuration Guide. That guide (I checked the 16.04 version for the 2930F, but newer versions and for other switches should have the same information) has a description on LLDP-MAD and VLAN-MAD, and one of the differences is that LLDP-MAD is easy to setup, and only works for 2-node VSF stacks, while VLAN-MAD supports more nodes but has some more constraints.
