Remote Networking
Re: RAP Configuration and Local DHCP
Why would split-tunnel not work? Users need an ip address from the headend so that they can send and receive requests to there is the main requirement for that. In Split-tunnel, users do not need an ip address on the local subnet to access local resources....
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
True, they don't.
The latency between the Shanghai office and the head office is very high, over 400 ms, it might cause some trouble, i'm not sure how sensitive the DHCP procedure is with latency.
So maybe i wasn't clear enough, we might go with the split-tunnel anyway, but without local DHCP.
So the desired setup (with local DHCP) is not possible with RAP/split-tunnel.
Thanks for explaining.
