Remote Networking
Re: RAP Deployment wants needed
Ok...Got everything set up the RAP from got it config using WPA2-AES-PSK, broadcast SSID asking for the PSK but can not get past that part. Keeps asking me for the PSK. If I change to just WPA2-AES then it will ask for logon but that fails as well. I think there is something blocking in the controller. Will the logs show these errors and if so what should I be looking for?
Thx
Ed
Ed,
Make sure on the controller that you put the key in as ASCII characters (PSK Passphrase) and not Hex. That option should be right below the section where you specify the key twice.
It in ASCII.
Ok..the issue I am having now is since my ISP has the controller in our DMZ is when users connect they are not getting auth whether it is PSK or User Login against Radius. Any thoughts or things to try?
Also, my system still has a local ip address that comes from the wireless router at my house, should it grab an IP from my internal DHCP?
Tx
Ed
