Remote Networking
Highlighted
Re: VIA Client losing Connection Profile and Going back to the Default
Right,
If I clear the profile I point at the controller and login I get the xxx_via_IT profile, I close the client and reconnect I get default when I connect and login to the controller I still get default which has nothing configured.
I have included all the show commands.
(Kings_VPN) #show aaa authentication via auth-profile default
VIA Authentication Profile "default"
Parameter Value
Default Role default-via-role
Server Group via_server_group
Description Default VIA Authenication Profile
(Kings_VPN) #show aaa server-group via_server_group
Fail Through:No
Auth Servers
Name Server-Type trim-FQDN Match-Type Match-Op Match-Str
NDS1 Ldap No
NDS0 Ldap No
Role/VLAN derivation rules
Priority Attribute Operation Operand Type Action Value Validated
1 groupMembership equals cn=vpn_users,ou=Services,o=xxx String set role xxx-via-role No
2 groupMembership equals cn=it_vpn_users,ou=Services,o=xxx String set role xxx-it-via No
(Kings_VPN) #show aaa authentication via connection-profile
VIA Connection Profile List
Name References Profile Status
xxx_via 1
xxx_via_IT 1
default 0
user-role xxx-via-role
via "xxx_via"
access-list session allowall
user-role xxx-it-via
via "xxx_via_IT"
Highlighted
Yes, but WHO are you logging in as when you connect and what role do they end up in?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Right I am logging in as me all the time and when I download the profile at the begin I get the xxx_via_IT one. After I connected and disconnect and loaded the client again I get asked to enter my username and password which I do, and I get the default one and won't let me change or use the xxx_via_IT one.
Highlighted
Hi Dude,
I found out now it keeps using the default role on the authentication profile and not going down to the ldap server to set the role based on the user.
Highlighted
I just confirmed that we do have a bug where the VIA connection using a non-default server-group in its auth-profile still derives role from the default server-group. This is scheduled to be fixed on ArubaOS 6.1.24 which is not out yet. You can either wait for that release or open a case for them to replicate your issue.
