Highlighted
Contributor I
2930F crash by login to web-gui with AAA Authentication enabled
I have three new aruba 2930F (24 and 48 Port).
I configured TACACS Login to console via Clearpass
aaa authentication ssh login tacacs local
aaa authentication ssh enable tacacs local
aaa authentication login privilege-mode
and Web Login via peap-mschapv2
aaa authentication web login peap-mschapv2 local
aaa authentication web enable peap-mschapv2 local
In this config the Switch sometimes crash and reboots after i entered my credentials in the web-login. Mostly when I'm already logged in with the same account via SSH.
Anybody experiencing the same problem? Any Solution
Firmware-Version:
WC16.08.003 and    WC.16.09.0001
Saved crash information:
Health Monitor: Write Error Restr Mem Access
HW Addr=0xe25bf24f IP=0x1e965d88 Task='tHttpd' Task ID=0x37a2d500
fp: 0x28dac30c sp:0x28dac2fc cpsr: 0x2000001f
Accepted Solutions
Highlighted
Contributor I
Re: 2930F crash by login to web-gui with AAA Authentication enabled
Firmware 16.09.003 should solve the Problem
CR_0000249696
Symptom/Scenario: When RADIUS authentication is configured for Web UI access and an attempt toestablish an HTTP connection is made to the switch from a web browser, the switch may crash with aHealth Monitor: Read Error Restr Mem Access message and Task='tHttpd'.
View solution in original post
All Replies
Highlighted
Do you see this on all 3 new switches?
Can your reproduce it, even when the rest of the config is default? so only the neccessery AAA/radius config in it.
any relevant log info? show log -r
- - - - Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE - - - -
- - - - - - - Feel free to give kudos or accept as a solution! - - - - - - - - -
Highlighted
MVP Guru
Switch crashes and reboots should be reported through Aruba TAC as they should never occur.
Highlighted
Contributor I
CR_0000249696
