I have successfully, I thought, integrated a Cisco 5508 WLC with CPPM. When I attempt to join the SSID I'm unable to do so and the only info I get is obtained from the Access Tracker which says Error Code 216 Authentication Failure-User authentication failed.
CPPM is definitely joined to the AD domain and it looks like my username I attempt to join the ssid with (which is in the ad tree) works but not the password. Any thoughts appreciated. THanks.
RADIUS MSCHAP: Authentication failed
EAP-MSCHAPv2: User authentication failure
2019-07-01 10:57:58,261 [Th 42 Req 64 SessId R00000008-01-5d1a2d85] WARN RadiusServer.Radius - AD - chidc.us.drwholdings.com: Password Attribute "userPassword" not available.
2019-07-01 10:57:58,327 [Th 42 Req 70 SessId R00000008-01-5d1a2d85] ERROR RadiusServer.Radius - rlm_mschap: FAILED: No NT/LM-Password. Cannot perform authentication.
2019-07-01 10:57:58,327 [Th 42 Req 70 SessId R00000008-01-5d1a2d85] ERROR RadiusServer.Radius - rlm_mschap: FAILED: MS-CHAP2-Response is incorrect
