Highlighted
Re: 802.1x authentication in Aruba/HPE switches
I was not aware of the RADIUS return with tagged and untagged VLANs. Thank you very much for the explanation!
Highlighted
Moderator
Please be aware that tagged VLAN and port auth mode VSAs cannot be used with user roles.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Regular Contributor II
Do you happen to know if and when DUR will be supported when IAP is in use for this exact scenario?
AMFX/ACEX #69
Aruba Partner Ambassador
Highlighted
Moderator
You’ll need to reach out to your Aruba team. Roadmap cannot be discussed in a public forum.
Highlighted
Will do. Thanks.
AMFX/ACEX #69
