Re: AccessCode only Web-login page with using clear pass guest.(Not user/pass)
Where do i find this "multi" in order to config the needed checkbox?
This is my gui:
Please Read the attached PDF in my other post. The full instructions are in there. It is what I followed to test.
Thank You,
Troy
Anything i sould configre in the instant excpet normal radius config + extranl Captive (that working for me) in front of the CPPM?
No you should set it up just like you would for normal guest access with CPPM.
https://ase.arubanetworks.com/solutions/id/37
Thank You,
Troy
:) that's what i said - Extranl Captive protal (the cPPM web-login page) + Extranl DB (The CPPM)
but thanks for the link
