Re: Advice to obtain Public Cert for Onboarding iOS Devices
but with free wifi you are not doing .1x so it shouldn't matter. It's only if you are doing 802.1x
Thank You,
Troy
Regular Contributor I
Free but self-registered wifi, so a user still hits guest and we don't the general public to get a certificate error :)
ACMA ACMP
again the Id-kp issue has nothing to do with https: it's only .1x that has the issue
Thank You,
Troy
I think you are saying that there is a 3rd solution which is:
- have a completely separate HTTPS cert, signed by a well-known Intermediate CA
- have a RADIUS cert signed by the OnBoard Local CA
But what if you have other 802.1x services that are not on-boarded? Same problem - the 802.1x clients will not have the OnBoard CA installed and will not validate the RADIUS cert.
So we are back to needing a RADIUS cert that is signed by a well-known intermediate CA and again the problem is that the internally created CSR doesn't have the right attribute. This goes back to my point about it not being a universal solution.
ACMA ACMP
most of the well know CA will add the attributes. You just need to call and request it with you csr.
This also comes down to security concerns. Do you really want a publicly signed radius cert. Most security experts will tell you that is a big security risk to take just for you to make it easier for some users....
Thank You,
Troy
Yes. The solution is to use a publicly signed https cert, an onboard signed radius cert and a supplicant configuration utility like QuickConnect for non-onboard clients.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
> That is why as of 6.3 you can have two separate certificates and we add ID-KP in our built in PKI that you can use the sign the radius certificate.
Giving this a go.. How does the signing work? I can create a CSR or self-signed cert in PM, but can't see how I sign it with the local CA.
edit: nevermind found it. I still think this will be an issue if you are supporting an onboard and a non-onboard 802.1x service but good enough for the moment
ACMA ACMP
If you do a csc from CPPM make sure you download both the CSR and the PKEY file.
1. If you havent already creat and new CA
2. Edit the CA settings for how long you want the certs to be valid.
3. click import cert
4. tell it to issue cert imedeately
5. export... I use PKCS7 because it includes the full trust chain.
6. Import into CPPM
Thank You,
Troy
I'm running into an issue. My thawte cert was issued for my VIP in my 5k cluster. However, it doesn't have id-kp-eapOverLAN option.
When trying to change my radius cert to be self signed, I get the error that CPPM can't use self signed certs for RADIUS in a cluster.
Is this normal?
cppm   6.3.3.29992
Josh
___________
ACMP, ACCP
Correct. Clustering requires that all certs be signed by the same CA which is not possible with a self-signed cert.
