Highlighted
Regular Contributor I
Re: Advice to obtain Public Cert for Onboarding iOS Devices
So...any suggestion other than not allow windows 8.1 or remove the VIP?
Josh
___________
ACMP, ACCP
Highlighted
You need to have the onboarding PKI sign the cert. the self sign does not support id-kp
Thank You,
Troy
Highlighted
Moderator
Are you using EAP-TLS / Onboard or just PEAP ?
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
doing EAP-TLS / OnBoarding
Troy - so if I sign it with OnBoard (like you show on page 2), I will be able to use the cert for radius and my VIP?
Josh
___________
ACMP, ACCP
Highlighted
Correct
Thank You,
Troy
View solution in original post
Highlighted
Thank you! That worked perfectly.
got to love certs!
Josh
___________
ACMP, ACCP
