Highlighted
AirGroup on AOS8 and IAP. [How to ?]
Hi Everyone,
I want to configuring up a apple classroom solution "AIRGROUP".
I have an idea like picture below.
Airgroup SolutionAirgroup SolutionAll devices are in same vlan1.
I need to classifiled student classroom A to see only appleTV-A.
Using AirPlay Mirroring Service.
Example:
Student username contain A (A001-A010) see only AppleTV-A.
Student username contain B (B002-B020) see only AppleTV-B.
Please help me deploy configuration to AOS8(Standalone) and IAP.
Thank you.
Best Regards.
BABABA
Highlighted
Re: AirGroup on AOS8 and IAP. [How to ?]
In AOS8, I just following configuration from user guide.
Already turn on the AirGroup feature, But i don't know how to map user id with apple-tv.
Can everyone give me idea how to make student username: A001 only AirPlay Mirroring on Apple-TV_A.
Thanks.
Highlighted
Highlighted
Hi cjoseph,
If i don't have ClearPass. I can't use AirGroup?
What solution can I deploy AirGroup without CPPM?
TQ.
Highlighted
At minimum you should be able to have any users on the cluster see mdns and dlna devices when "Broadcast filtering" is set to ARP or ALL.  Typically discovery of mdns and dlna devices would be blocked when you set Broadcast Filtering to ALL or ARP on an SSID.  Airgroup makes it so that you can have improved performance with broadcast filtering, but users will still be able to discover devices using mdns or dlna.
Further, you should be albe to allow or block device discovery based on VLAN or Role.
To specify what usernames would be able to connect what devices, requires ClearPass.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Done!!!
I use server base policy equal username.
*** I have a question about.
How many AppleTV limitation of AirGroup on 1 standalone controller?
Or no limit?
Server Base PolicyServer Base Policy
Highlighted
MVP
Hey Bababa
Were you able to solve the same on IAP? That screenshot you have added is from an AOS8 Controller.
I'm just trying to figure out if Auto-associate is available for IAP or not..
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
