Occasional Contributor I
Airplay through Airgroup drops after 30 seconds
Dear,
We have 2 mobility controllers (active - active):
When setting up Airgroup for Airplay the connection drops after exactly 30 seconds if the 'user' and 'server' are on a different VLAN. This is reproducible and happens every time.
If 'user' and 'server' are on the same VLAN, the connection is stable.
Is there some kind of setting that drops the connection after 30 seconds?
What could be the issue?
Thank you!
Ben
MVP Expert
Re: Airplay through Airgroup drops after 30 seconds
Might be worth checking the following commands:
show airgroup blocked-queries
show airgroup blocked-service-id
Koen (ACMX #351 | ACDX #547 | ACCP)
EdW
I found with the most reason firmware version 8.3.0.6_69128 on my IAP 305's mDNS just fails at the AP.  I was able to verify this by downgrading firmware and it worked prior to the most recent update.
Any help with this issue is greatly appreciated.
Super Contributor II
I should say contact TAC for this.
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
