Regular Contributor II
Re: Android and Mac trouble connecting to the guest wireless
When we upgraded from 3.3.x series of code to 5.0.x series of code, that the DHCP IP binding did not release. I had to delete the IP range for the guest SSID then recreate it.  You can use the following to see the DHCP lease status:
show ip dhcp status
It just happened to be Android and a few MACs trying to get on to the network at that time.
I would also like to know more about this issue.
I'm seeing problems in spots.  Particular APs not responding to requests for iPads and Macs.
