Aruba 501 Wireless Bridge Passphrase Update
Is there a way to automatically update the WPA/WPA2  passphrase on an Aruba 501 Wireless Bridge?
We are currently using Save/Restore function to transfer device settings between the wireless bridges, just looking for another option.
Thanks in advance.
MVP Expert
Re: Aruba 501 Wireless Bridge Passphrase Update
I'm not sure if there are central management capabilities for this bridge. The last few I had to set up was not pleasant.
Possibly it could be managed by Airwave? Even if so, that would require actually having Airwave implemented.
Sean Rynearson
Smart Spaces TME
Phone: 706.972.1520
Twitter: @srynearson
Airheads: @srynearson
