Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
I have a problem with the clearpass when I send a Radius Coa to the switch. It always gives me the same error:
0000:00:25:52.77 RAD tRadiusR:DISCONNECT REQUEST id: 7 from 10.253.27.12
DROPPED, Invalid packet authenticator.
I have no problem in the validation user through 802.1x. It works well and in Clearpass validates, however when I send an RCoa the switch does not respond and makes a drop of the package.
This is what I have configured in the switch:
radius-server host 10.253.27.12 encrypted-key "encripted_key"
radius-server host 10.253.27.12 dyn-authorization
radius-server host 10.253.27.12 time-window 0
SW(config)# sh radius
Status and Counters - General RADIUS Information
Deadtime (minutes) : 0
Timeout (seconds) : 5
Retransmit Attempts : 3
Global Encryption Key :
Dynamic Authorization UDP Port : 3799
Source IP Selection : 192.168.116.13
Source IPv6 Selection : Outgoing Interface
Tracking : Disabled
Auth Acct DM/ Time |
Server IP Addr Port Port CoA Window |
Encryption Key
10.253.27.12 1812 1813 Yes 0 | encripted_key
                                    Disc      Disc    Disc    CoA     CoA   CoA
IP Address                 Reqs   ACKs  NAKs   Reqs   ACKs   NAKs
10.253.27.12                 12      0          0       3            0            0
Can you help me?
TY
MVP Guru
Re: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
check whether below setting configured properly
  • RFC server IP configuration and shared secret
  • Port 3799 is allowed
  • What type of Radius CoA template you are using?
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
MVP
MVP
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
  • RFC server IP configuration and shared secret --> Yes, i can do 802.1x.
  • Port 3799 is allowed--> Yes, i receive in switch radius coa
  • What type of Radius CoA template you are using? --> [ArubaOS - Terminate Session]
  • Another one--> Same NTP Server
I try with differents templates for Radius_Coa and ever i receive same error --> Invalid Packet Authenticator.
Looks like you want a Disconnect, not a CoA. Use the [ArubaOS Switching – Terminate Session] profile.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
I want a radius coa, i use [ArubaOS switching - Terminate sesion] but i can use other, only want radius coa work fine.
I try a diferents templates but none works
If you’re trying to Disconnect the user, it’s a Disconnect, not a CoA. [ArubaOS Switching - Terminate Session] is the correct enforcement profile.
Nice, i change profile, now i send Coa but i ve same error: invalid packet authenticator.
