ArubaOS 8 - Guest / Clearpass issue
  • 1.  ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 27, 2019 08:53 AM
    Dear Experts,
    I am trying to configure 7005 (running 8.3) with CPPM Guest (6.7). I have uploaded cert (wildcard) of my company and able to access the web gui of the controller easily. My web-server profile is as per attached. I have configured the roles and everything and when i connect my user device to a-guest (SSID) i am able to get the IP, ping DNS server, able to resolve bbc.com (for example) IP also without any issue but when i open the browser, it doesnt redirect me to my cppm portal page. Can someone advise what i might be doing wrong, and also what do i need to enter on the cppm self registration side, can i enter mc1.mycompany.com.pk? (mycompany.com.pk will be replaced with my actual domain)
  • 2.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 27, 2019 09:29 AM
    Can you share the ACLs under the captive portal role ?
    Sent from Mail for Windows 10
  • 3.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 04:07 AM
    Dear Victor, Please find below
    Role name: a-guest-guest-logon
    user-role a-guest-guest-logon
    captive-portal "a-guest"
    access-list session global-sacl
    access-list session apprf-a-guest-guest-logon-sacl
    access-list session http-traffic
    access-list session logon-control
    ip access-list session http-traffic
    any host 192.168.30.201 svc-http permit
    any host 192.168.30.201 svc-https permit
    any host 192.168.30.100 svc-http permit
    any host 192.168.30.100 svc-https permit
    user host 192.178.30.100 svc-http permit
    user host 192.168.30.201 svc-http permit
    user host 192.168.30.201 svc-https permit
    user host 192.168.30.100 svc-https permit
    user host 192.168.30.100 svc-http permit
    ip access-list session logon-control
    user any udp 68 deny
    any any svc-icmp permit
    any any svc-dns permit
    any any svc-dhcp permit
    any any svc-natt permit
    any network 169.254.0.0 255.255.0.0 any deny
    any network 240.0.0.0 240.0.0.0 any deny
    When i connect my mobile, i am getting the correct role (a-guest-guest-logon) and i am able to resolve any public domain as well which means dns queries are just fine. When i try to browse anything, it doesnt redirects me to captive portal, if i type the address of CPPM or Captive-portal-login.<my-domain> it doesnt open the page either.
    Any idea what i might be doing wrong?
  • 4.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 07:48 AM
    Dear,
    I have simplified the access-list using http-traffic only. Below is the excerpt now, i am able to manually open the cppm page successfully but when i connect my mobile, it shows no internet and doesnt automatically pops the CP. Also when i try to manually enter any public website on webpage, it doesnt reload neither it redirects. I was testing on 8.3, now i upgraded to 8.5 but still the same issue
    I am attaching the configuration, if anyone can help out what i might be doing wrong
    Attachment(s)
    txt
    Controller.txt   48 KB 1 version
  • 5.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 08:27 AM
    You need the captiveportal acl which forces the client to get redirected to the captive portal page :
    Note: Replace the under the netdestination for the ClearPass real IPs
    netdestination clearpass-server
    host
    host
    aaa authentication captive-portal "a-guest"
    white-list "clearpass-server"
    a-guest-guest-logon
    access-list session captiveportal
    Try replacing the
  • 6.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 08:49 AM
    Dear Victor,
    I made the changes and got it to work but now i am stuck at login. When i register the user and press login, its giving below error. Can you please help to resolve this issue
    https://captiveportal-login.<mydomain>/cgi-bin/
    This captiveportal-login.mydomain page can’t be found
    No webpage was found for the web address: https://captiveportal-login.mydomain/cgi-bin/
    HTTP ERROR 404
  • 7.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 09:18 AM
    Did you replace the default controller certificate ? and if so make sure it is applied under the Captive Portal Certificate (Configuration > System > More > General)
  • 8.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 09:25 AM
    Yes i changed the default certificate with a wildcard. I have also applied it under the location you have mentioned. Below is the output of webserver profile
    Web Server Configuration
    Parameter Value
    Cipher Suite Strength high
    SSL/TLS Protocol Config tlsv1 tlsv1.1 tlsv1.2
    Switch Certificate MC1
    Captive Portal Certificate MC1
    IDP Certificate MC1
    Management user's WebUI access method username/password
    User absolute session timeout <30-3600> (seconds) 0
    User session timeout <30-3600> (seconds) 900
    Maximum supported concurrent clients <25-320> 75
    Enable WebUI access on HTTPS port (443) false
    Enable bypass captive portal landing page false
    Exclude Security Headers from HTTP Response false
    VIA client-cert port number 8085
    Its not able to find the particular url.
  • 9.  RE: ArubaOS 8 - Guest / Clearpass issue
    Posted Aug 29, 2019 10:59 AM
    Dear Experts,
    Any hint on what i might be missing, i had it all working (except the wildcard cert) back in 6.5 code. I am not sure what i am missing here, trying for hours to get it to work :(
    I have enabled switch certificate + server certificate (both are same wildcard cert). But when i press the log in button on CP page, i get redirected to captiveportal-login.mydomain with blank page. No activity can be seen on access tracker or event viewer.
    Any ideas please?
