Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Auth priority vs auth order
I am trying to figure out the difference while configuring Cisco switch between the command
Authentication priority dot1x mab
And
Authentication order dot1x mab
Also what does fallback actually means ?
Does it mean that when dot1x fail then next try for mab ?
Accepted Solutions
Highlighted
Moderator
Re: Auth priority vs auth order
You should always define both. Generally you want dot1X to fire first and dot1X to take priority.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
View solution in original post
All Replies
Highlighted
Moderator
Auth order is the order in which they fire.
Auth priority means which result will take precedence for an accept.
Highlighted
Ok thanks Tim
Do we need to configure both commands ?
My need is to always give priority to dot1x and then mab on per port basis
What if I don't define order command ? Is there any global way to always make an order dot1x and then mab ?
Highlighted
Moderator
Highlighted
Ok thanks Tim as always
Highlighted
We're you able to successfully implement this?
I try to achieve that dot1x takes place first followed by mac auth because we enforce a mac default role to place the clients into a guest role. Due to parallel authentication (2930F switch) mac auth takes place first (maybe only 500ms earlier than dot1x enforcement) almost everytime. During this time clients are already getting a IP address from the guest network and the dhcp reservers an IP address for a client that doesn't need one.
To solve this issue I configured "aaa port-access auth-order authenticator mac-based". Due to default dot1x supplicant-timeout I set the timeout to 3secs in the hope MAC auth takes place if there is no dot1x after 3 secs. However it takes about 90secs unitl mac auth is performed (starting from "… m8021xCtrl:Port 3: connection detected.")
Debug Logs:
0000:00:23:29.58 1X   m8021xCtrl:Port 3: connection detected.
0000:00:23:29.58 1X   m8021xCtrl:Port 3: sent ReqId #1 to 0180c2-000003.
0000:00:23:29.64 1X   m8021xCtrl:Port 3: added new client 9457a5-be3040.
0000:00:23:58.60 1X   m8021xCtrl:Port 3: sent ReqId #1 to 9457a5-be3040.
0000:00:23:58.60 1X   m8021xCtrl:Port 3:No. of EAP Id request sent: 1 to
   client:9457a5-be3040.
0000:00:24:28.60 1X   m8021xCtrl:Port 3: sent ReqId #1 to 9457a5-be3040.
0000:00:24:28.60 1X   m8021xCtrl:Port 3:No. of EAP Id request sent: 2 to
0000:00:24:58.60 1X   m8021xCtrl:Port 3: There is no EAP response from
0000:00:24:58.60 AUOR  m8021xCtrl:Auth Order: Port 3:Added auth order client:
   9457a5-be3040.
0000:00:24:58.60 AUOR  m8021xCtrl:Auth Order: Port 3: Client status updated for
   client: 9457a5-be3040, auth-method: 1 , auth-state: 1 .
0000:00:24:58.60 1X   m8021xCtrl:Port 3:Auth order: Mac authentication will be
   triggered client: 9457a5-be3040 as there is no EAP response.
0000:00:24:58.60 AUOR  m8021xCtrl:Port 3:Mac authentication is triggered for
0000:00:24:58.60 1X   m8021xCtrl:Port 3: Deleted Client 9457a5-be3040User (null)
   from Client-List
0000:00:24:58.60 MAC  mWebAuth:Port: 3 MAC: 9457a5-be3040 new client detected on
   vid: 1.
0000:00:24:58.60 MAC  mWebAuth:Port: 3 MAC: 9457a5-be3040 RADIUS CHAP
   authentication started, session: 8.
0000:00:24:58.64 MAC  mWebAuth:Port: 3 MAC: 9457a5-be3040 RADIUS Attributes,
   vid: 64.
0000:00:24:58.64 MAC  mWebAuth:Port: 3 MAC: 9457a5-be3040 [8] client accepted
   with role 'guest'.
0000:00:24:58.64 MAC  mWebAuth:Port: 3 MAC: 9457a5-be3040 client successfully
   placed into vid: 64.
0000:00:24:58.64 AUOR  mWebAuth:Auth Order: Port 3: Client status updated for
   client: 9457a5-be3040, auth-method: 2 , auth-state: 2 .
0000:00:25:00.60 1X   m8021xCtrl:Port 3: sent ReqId #1 to 0180c2-000003.
Portconfig:
interface 3
   name "NAC"
   qos trust dscp
   rate-limit bcast in percent 2
   rate-limit mcast in percent 2
   untagged vlan 2000
   aaa port-access authenticator
   aaa port-access authenticator supplicant-timeout 3
   aaa port-access authenticator client-limit 16
   aaa port-access mac-based
   aaa port-access mac-based addr-limit 16
   aaa port-access controlled-direction in
   spanning-tree admin-edge-port
   spanning-tree bpdu-protection
   exit
Tested with:
WC.16.10.0005
WC.16.09.0004
I configured "aaa port-access authenticator max-eap-retries 1" this saves 30sec. This shows me the "aaa port-access authenticator supplicant-timeout 3" does not take place.
Otherwise I have to implement a "WAITFOR" in the SQL query for querying the Clearpass Guest Device Repository to achieve a mac auth delay.
Are there any other options?
Highlighted
Frequent Contributor II
Hi!
For instance you can reduce the tx-period (default 30 sec.):
aaa port-access authenticator 2/I20 tx-period 10
With this example you can reduce the time between the first 802.1x try and receiving the mac auth role to 25 to 30 seconds (realtime, from pluging in the cable).
Best regards/Mit freundlichen Grüßen
Matthias
Highlighted
After a few lab tests may I say the following interface config is needed to speed up the dot1x process in order to perform mac-authentication:
aaa port-access authenticator <INTERFACE> tx-period 1
aaa port-access authenticator <INTERFACE> max-eap-retries 1
aaa port-access <INTERFACE> auth-order authenticator mac-based
aaa port-access <INTERFACE> auth-priority authenticator mac-based
With this configuration mac-authentication is performed after 4-5 seconds which is acceptable. We didn't gain any experience in a operative environment with it so far (only lab) but we'll see how the config is going to affect dot1x clients soon.
Highlighted
Yes, I would also test this short tx-period with all your 802.1x clients.
If they miss the 802.1x period, they my fall back to mac auth...
Matthias
