Highlighted
Occasional Contributor I
Authentication Open - Hpe 5100
Is there an equivalent command or documentation about rolling of clearpass and HPE 5100 dot1x with the cisco "Authentication open".
What we would like to do is to allow access even if a user fails authentication while we asses the impact.
Cisco ISE has a rollout procedure with clear documention for this.  I can't find it for HPE so far.
thanks
Highlighted
Moderator
Re: Authentication Open - Hpe 5100
What is the exact switch model? I'm not familiar with a 5100 model.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
5100 series  -we have a mix of 5120 and 5130
Release Version: HPE 5130-48G-4SFP+ EI JG934A-3113P05
Highlighted
Moderator
https://community.arubanetworks.com/t5/Security/ClearPass-Solution-Guide-Wired-Policy-Enforcement/td-p/298161
