Hi
i have a small IAP deployment running to do some Test.
All AP´s/IAP/VC´s on the same L2 .
The default behavior is that as soon a VC is discovered via L2 by the other IAP´s it will join the VC and get the config and Software.
My Unterstanding was that this behavior can disabled by "auto Join" disable.
But if I disable this feature nothing changes.
AP´s always join the VC regardless of whether it is a brand new IAP out of the box or a Factory Resetted IAP. What could be wrong ?
I use Airwave 8.2.10 and 6.5 on the IAP´s .
My Concerns are security related because in this Scenario everybody could connect a Aruba AP to the L2 and get access to the Net via wifi , I guess it would be better to confirm new IAP´s to the VC as intended by a "disabled Auto Join" feature.
Regards Markus
