Highlighted
Blacklisting users
In clearpass monitoring there is a blacklist users table where you can view blacklisted users and delete them from the blacklist ......
Can't seem to find info in the help system as to how you actually blacklist a user/mac address.
Searching for blacklist just gives you the Monitoring table
Running 6.8
Accepted Solutions
Highlighted
Re: Blacklisting users
The blacklist table in monitoring is only used by the built in guest. When a device is expired it will role into the blacklist table. If you want to blacklist your own device/user then you can just add a custom attribute and filter on that in your service.
Thank You,
Troy
View solution in original post
All Replies
Highlighted
Thank You,
Troy
Highlighted
o.k. fair enough. We do "things" to blacklist people anyway,just wondered if it was a general "blacklist feature" in policy manager
