Regular Contributor I
CIsco WLC RADIUS:Airespace problem
Guys, i have an issue integrating Cisco WLC using external captive portal to Clearpass.
when i try to use RADIUS:Airepace to enforce it back to the Cisco WLC, the user stuck in login loop.
if the RADIUS:Airepace enforcement removed, user login fine but without proper acl.
I have enabled Radius:Airepace dictionary.
Ricky E. Lee
CWNA | ACMP | ACCP
