Highlighted
CLEARPASS Network Devices Attributes
I know it is possible to use Device Attributes in a Service Rule,
But we also would like to use NAD Device Attribute values in an Enforcement profile
The question is: is this possible?
And if this is possible how can we get access to these atributes
Highlighted
Re: CLEARPASS Network Devices Attributes
The NAD "attributes" appear in the AccessTracker event's Input-->Computed section. In my example I have Device:Device Type, Device: Device Vendor and Device:Location. I believe these can be referenced using %{Device:Location}. Hence, you should be able to use these to differentiate the policy assigned to say a 2930 switch v CX.
Annoyingly the Vendor information is not natively available. Though it shouldn't be too hard to use the XML to add attributes.
Highlighted
Frequent Contributor II
You can always add your own device attribute to use for enforcement. You can also define your own Device attribute by going to Administration > Dictionaries > Dictionary Attributes. Click on add new, choose a Entity type of device, and choose a Data Type of String. Name your attribute, and then click Add. See attached screen shots.
Dustin Burns
Senior Mobility and Access Engineer @WEI
ACMX#509 | ACCP | ACSA | CCNP | CCDP | CCNA Wireless
Highlighted
Got it, thanx!
