Highlighted
Frequent Contributor I
CLearpass Downloadable roles with Aruba 2930f switch
Hi I have few questions,
I am building network for client demo and want to show him downloadable roles with (QoS, ACL and so on) from Clearpass.
I have evaluation CLearpass server with self signed  https certificate, Wired Policy Enforcement guide says that I need to install clearpass root ssl certificate to swtich trusted anchors repository.
I downloaded Clearpass self signed SSL certificate root from web browser and try to push it to switch over tftp, but switch do not accept it,
I tried all certificate types : der, base-64, pem, p7b but it only says that
"Aruba-2930F-8G-PoEP-2SFPP# copy tftp ta-certificate DEMO 192.168.77.92 DEMO.crt
000M Transfer is successful
Invalid Trust Anchor certificate.
Aruba-2930F-8G-PoEP-2SFPP# Invalid Trust Anchor certificate"
Can someone  explain whhat I am doing wrong?
Highlighted
Moderator
Re: CLearpass Downloadable roles with Aruba 2930f switch
Self-signed certificates are not supported.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
So for Clearpass downloadable roles demo deplyoment I need to buy public SSL certificate? Really?
Highlighted
Moderator
Non self-signed != Public
It can be from an internal PKI or ClearPass itself, however, it is very rare to not have a public HTTPS cert for ClearPass as it is require for many functions.
Highlighted
Occasional Contributor I
You don't have to buy certificate for the demo or production. Public cert s are good for hotspot or onboard. For radius you can make certificate request from clearpass and sign it with your internal cert server. it worked for me.
Highlighted
I had the same issue, the following worked for me.
I went to Administration>Certificates>Trust list, clicked on cert with subject "Aruba Networks Trusted Computing Root CA", enabled it, exported to TFTP, then copied to switch. The switch took it.
Highlighted
Clearpass version 6.9
