Hi community,
I have a customer who has purchased two C1000 ClearPass appliances, just for redundancy, so I will create a cluster of two nodes, both if the same L2 segment. The number of users to be authenticated is very small, no more than 200 concurrent users, so the two nodes will be sharing 200 Access licenses. For the wireless side I have a cluster of IAPs. In this case where the number of users is very small and the ClearPass nodes can handle with no problems the authentication requests, is it better if I configure my Instant cluster to load balance the traffic between the two ClearPass nodes (active-active) or to send all the traffic to one node and let the other node as backup in case the primary node fails (active-standby)? Both options will work, which one is better?
Julián
