MVP Expert
CPPM Block RADIUS Req from NAD
I've been getting alerted for multiple failed RADIUS attempts from a specific NAD, which I found is a security device attempting RADIUS requests toward CPPM looking for vulnerabilities. This is generating alerts which I receive via email.
This made me wonder, Is there any way to block traffic from a specific host, an internal firewall or something on CPPM? Application Restrictions don't cover RADIUS/TACACS requests.
Thanks.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Re: CPPM Block RADIUS Req from NAD
No
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
MVP Expert
Easy enough, thanks.
Michael Haring
The solution is really the same as any other server in a datacenter using datacenter firewalls to restrict access.
