Highlighted
CPPM C1000 use case
So what sort of environment would you use a C1000 in?
Seems awfully slow ... 386 perhaps ?
A
Highlighted
Re: CPPM C1000 use case
Check out the scaling / ordering guide which details the number of concurrent session etc..
Here's a chart from the guide:
Cheers
James
