CPPM Port Assignment for TACACS+ & RADIUS & Guest Portal
What is the best practice for CPPM port assignment?
Option 1
Single Data port for TACACS+ & RADIUS & Guest Portal? or
Option 2
Management Port for TACACS+ & RADIUS
Data Port for Guest Portal
Which one is better and why?
Thanks.
David
MVP Guru
Re: CPPM Port Assignment for TACACS+ & RADIUS & Guest Portal
David,
Check this technote for details on port configuration
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33293
To keep simple, it is good to have single managment port configuraiton for all traffic, rather going for two ports.
Pavan
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
