last person joined: 8 hours ago
CPPM - Procurve port goes offline several times before client finish auth
  • 1.  CPPM - Procurve port goes offline several times before client finish auth
    Posted Jan 20, 2019 06:47 PM
    got ClearPass working but started receiving random people complaining that they could not login.
    Switchport gets turned off/on several times while the user logins causing all sort of issues:
    I 01/21/19 10:14:19 00076 ports: ST1-CMDR: port 1/21 is now on-line
    I 01/21/19 10:14:19 00435 ports: ST1-CMDR: port 1/21 is Blocked by STP
    I 01/21/19 10:14:19 00435 ports: ST1-CMDR: port 1/21 is Blocked by AAA
    I 01/21/19 10:14:16 00077 ports: ST1-CMDR: port 1/21 is now off-line
    I 01/21/19 10:14:10 00076 ports: ST1-CMDR: port 1/21 is now on-line
    I 01/21/19 10:14:10 00435 ports: ST1-CMDR: port 1/21 is Blocked by STP
    I 01/21/19 10:14:10 00435 ports: ST1-CMDR: port 1/21 is Blocked by AAA
    I 01/21/19 10:14:07 00077 ports: ST1-CMDR: port 1/21 is now off-line
    I 01/21/19 10:14:06 00076 ports: ST1-CMDR: port 1/21 is now on-line
    I 01/21/19 10:14:06 00435 ports: ST1-CMDR: port 1/21 is Blocked by STP
    I 01/21/19 10:14:06 00435 ports: ST1-CMDR: port 1/21 is Blocked by AAA
    I 01/21/19 10:14:04 00077 ports: ST1-CMDR: port 1/21 is now off-line
    Port configuraiton:
    untagged vlan 11
    no port-security eavesdrop-prevention
    aaa port-access authenticator
    aaa port-access authenticator auth-vid 11
    aaa port-access authenticator client-limit 2
    aaa port-access authenticator cached-reauth-period 86400
    aaa port-access mac-based
    aaa port-access mac-based addr-limit 4
    aaa port-access mac-based logoff-period 9999999
    aaa port-access mac-based reauth-period 86400
    aaa port-access mac-based cached-reauth-period 86400
    aaa port-access controlled-direction in
    spanning-tree admin-edge-port
    ClearPass does not report any issues. Also logs in ClearPass are 30 seconds behind vs switch logs, but switch and ClearPass are on the same exact time to the second.
    I have opened a case but wondering if you have any clues.
    thanks
  • 2.  RE: CPPM - Procurve port goes offline several times before client finish auth
    Posted Jan 20, 2019 07:30 PM
    Did you follow the ClearPass Solution Guide for Wired Policy Enforcement?
  • 3.  RE: CPPM - Procurve port goes offline several times before client finish auth
    Posted Jan 20, 2019 08:00 PM
    Thanks. I went through that document a million times and that configuration never worked for a number of reasons, mostly related for headless devices and MAC auth. In fact we went on for about a month with HPE support (and a thread that went unanswered here) because printer would never pass MAC address auth (with the configuration in the document you are referring to) and neither support could find the cause, blamed us, and closed the case.
    We have found the answer on a reddit post purely by chance which solved the problem (control direction in and disabling eavesdrop prevention).
    I find ClearPass/Procurve auth extremely incosistent at best and I wonder how on earth people got it to work.
    Sorry for the rant.
  • 4.  RE: CPPM - Procurve port goes offline several times before client finish auth
    Posted Jan 24, 2019 07:15 AM
    we have procurve switches and it works well.  Assuming you have the latest firmware on them our config is as follows for a single port number 1
    aaa port-access authenticator 1
    aaa port-access authenticator 1 auth-vid 104
    aaa port-access authenticator 1 Client-limit 1
    aaa port-access authenticator 1 quiet-period 30
    aaa port-access authenticator 1 logoff-period 862400
    aaa port-access authenticator active
    aaa port-access mac-based 1
    aaa port-access mac-based 1 logoff-period 862400
    aaa port-access mac-based 1 quiet-period 30
    aaa port-access mac-based 1 auth-vid 104
    you don't need controlled direction in (unless you are using wake on lan) and I havent seen eavesdrop prevention in the documentation HP sent us
  • 5.  RE: CPPM - Procurve port goes offline several times before client finish auth
    Posted Jan 24, 2019 09:10 PM
    thanks for your answer. Yes the issue was resolved (problem on ClearPass not the switch).
