MVP Guru
Re: CPPM - Using same public certificate for Captive Portal and Radius Server
Agree with Tim, I may have jumped over that. Use the group policy to push your (self-signed) private CA root, and issue your RADIUS cert from there. The RADIUS (EAP) cert itself indeed should not be self-signed.
Understood, now I'm checking if I can install AD CS and I'll try to create a Certificate with AD. If it will not work I'll purchase a public certificate.
Thanks both for your help
Best Regards
Giuseppe Pasinell
Hi all,
I create certificate with AD Certification Service, I uploaded it to CPPM as Radius Certificate and every works.
Thanks for yours help
Best Regards
Giuseppe
