Contributor II
Re: CPPM and Insight
@cappalli
Thanks for the post I was having the same issues replicating a customer issue and I didn't even see that small checkbox listed. We were having issues getting data from the insightDB and it almost seemed that info was not being passed from the Endpoints Repisotory to Insight Repisotory.
I did see some of your other posts in regards to selecting the Insight for Authorization, although that only helps if the Insight is enabled.
Thanks again!
Justin Kwasnik | ACMX# 598 | ACCX# 638
