Highlighted
Can i configure Onconnect in front of Juniper EX4300?
Hi AirHeads,
When trying to configure simple OnConnect enforcement based on SNMP in front of Juniper EX4300 (17.3R31 Version)
Im getting an alert on the CPPM:
SNMP SERVICE: VLAN enforcement not supported for NAD = XXX.XXX.XXX.XXX (The Switch IP)
Please advise,
Does Junipers switches supporting OnConnect capabilites ?
Accepted Solutions
Highlighted
Moderator
Re: Can i configure Onconnect in front of Juniper EX4300?
Juniper is not supported with OnConnect due to their lack of support for SNMP write. The ClearPass Solution Guide for Wired Policy Enforcement has configurations for all supported switches.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
View solution in original post
All Replies
Highlighted
Moderator
Highlighted
Thank u!
Appreciate your fast response.
