Captive Portal Issue with Aruba Controller 650
  • 1.  Captive Portal Issue with Aruba Controller 650
    Posted Oct 03, 2019 11:20 PM
    I have an Aruba 650 controller and the controller is running on the code 6.4.2.12. Recently Implemented Guest Wifi but not able to get the login page from captive portal.  Below is the error messsage
    "No webpage was found for the web address: https://mess-hot-aruba-650/upload/custom/MESS-Guest-Captive-Portal-profile/i.html
    HTTP ERROR 404"
    Uploaded the i.html file, jpeg file but still not working..
    TAC engineer seems like unable to provide the solution for this Issue.
    If anybody had the similar Issue and shed some light on this will be appreciated.
  • 2.  RE: Captive Portal Issue with Aruba Controller 650
    Posted Oct 04, 2019 02:52 AM
    What about when you use one of the readily available captive portal pages?
    Is the mapping of the captive portal page done properly to the Auth profile?
    Show AAA authentication captive-portal MESS-GUEST-CAPTIVE-PORTAL-PROFILE
    Or whatever authentication profile you are using for captive portal
    Do you see any errors in " show profile-errors " for the captive portal profiles?
