Captive Portal re-authentication interval
I deployed a captive portal authentication on aruba controller for one of my client and i configured a user idle timeout  to 255 min to force the reauthentication of guest users after 4 houres, but my client want to stay connected for 2 days even if he is not generating trafic.
Is there any solution on aruba controller to adress this need.
Aghiles
MVP
MVP
Re: Captive Portal re-authentication interval
What is the goal for this solution? captive portal with mac-caching is recommended in most cases.
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
MVP
MVP
Frequent Contributor I
