Highlighted
Captive portal exceptions
we're using an open SSID wifi solution, with captive portal enabled. Is there a way, to have some exceptions? I mean - for example - to enable connections towards an VPN concentrator WITHOUT having to open&click the captive portal. Is there a way for it?
            Tom
Accepted Solutions
Highlighted
Re: Captive portal exceptions
Yes. Just add a firewall policy to allow the traffic in the initial role (guest-logon or whatever) on the guest Wi-Fi.
user -> vpn concentrator -> vpn ports -> permit
Cheers
James
View solution in original post
All Replies
Highlighted
Cheers
James
Highlighted
Thx!
