Frequent Contributor II
Captiveportal, roles and vlans
Hi!
I'm trying to setup a solution where the initial role has vlan x and after the user has authenticated with captive portal (internal via radius) the authenticated role gets vlan y.
show aaa debug vlan user ip x.x.x.x
VLAN types present for this User
Default VLAN : y
Initial Role Contained : x
VLAN Derivation History
VLAN Derivation History Index : 12
1. VLAN 0 for Reset VLANs for Station up
2. VLAN y for Default VLAN
3. VLAN y for Current VLAN updated
4. VLAN x for Initial Role Contained
5. VLAN x for Current VLAN updated
6. VLAN x for VLAN exported
7. VLAN 0 for Reset VLANs for Station up
8. VLAN y for Default VLAN
9. VLAN y for Current VLAN updated
10. VLAN x for Initial Role Contained
11. VLAN x for Current VLAN updated
12. VLAN x for VLAN exported
Current VLAN : x (Initial Role Contained)
But the user seems to keep vlan x all the time, is this not supported ?
Not sure I understand this correctly, maybe my soultion isn't supported ?
https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-does-L2-authentication-based-vlan-derivation-work-Explain/ta-p/177408
ACMP | ACCP
Re: Captiveportal, roles and vlans
Not supported.  Mainly because the client has no way to detect that the VLAN has changed.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
aha ok. I'm having issues with a pbr-route on the vlan interface of guests. So I figured I could just move them to another vlan temporary.
CP just won't redirect if I have pbr-route on the guestvlan interface.
ACMP | ACCP
