ClearPass 6.8 with YeaLink T21P 802.1x EAP-PEAP do not wotk
Hi, can some one had this king of issue:
I have installed CLearPass 6.8, authenticating all client  PCs and Users using EAP-PEAP, but the same policy does not work with YeaLink T21P VoIP phones and problem showing on access tracker is
"EAP-PEAP: fatal alert by client - bad_certificate"
As I understand VoIP phone do not trust my clearpass RADIUS server certificate. I have tried all types of certificates to upload to this VoIP phone but the error is always the same.
I am adding VoIP phone config and ClearPass service config and error.
