ClearPass Eval for CPPM 6.8
  • 1.  ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 05:13 AM
    Good Morning,
    does the ClearPass Eval-Keys I as a Partner can generate in ASP works as well for a new installation with 6.8.
    Or do we have to install first 6.7.9 and than upgrade to 6.8?
    Example for EVAL-KEY
    Part Number : JZ399AAE
    Part Description : Aruba ClearPass Cx000V VM Appl E-LTU
    Product Activation Key : YUOM-UMA455-TQE6-TK4HPN-3LKJRI-SM5T-IUB2BS-L52FE3-XXXXXXXXXXXXXXXXXX
    Version : 6.7.X.X
    ExpiryDate : 6/19/2019
  • 2.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 05:28 AM
    Are you not seeing software version 6.8 in drop down list while genertating Eval license?
    If you are not seeing then try reach customer support to check for details.
  • 3.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 06:31 AM
    License keys in 6.8 are a slightly different format. There should be an option for 6.8 when generating an eval.
  • 4.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 07:29 AM
    I also see that the dropdown box only has 6.7.x.x in the LMS tool.
    Do we have to contact TAC for an EVAL KEY?
  • 5.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 07:49 AM
    Yes, if you want 6.8 Eval key then contact TAC and also check why you are not seeing 6.8 in your drop down.
  • 6.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 09:23 AM
    Problem fixed with my local SE.
    Thanks to all for your support
  • 7.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 01:48 PM
    the dropdown to select version to generate eval keys only shows 6.7.x; no 6.8.x option yet.
    TAC generated new "Enhanced" codes for me pretty quickly.
  • 8.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 21, 2019 02:01 PM
    The LMS team is working on it. Thanks for your patience.
  • 9.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 22, 2019 08:20 AM
    The option to generate eval licenses for Clearpass 6.8 is now available in LMS.
    Licensing team fixed it, option 6.8 added.
  • 10.  RE: ClearPass Eval for CPPM 6.8
    MVP GURU
    Posted Mar 22, 2019 09:38 AM
    What the format of key ? because i have a
    -----BEGIN CLEARPASS PLATFORM LICENSE KEY-----
    H4sIAAAAAAA..... -----END CLEARPASS PLATFORM LICENSE KEY-----
    But don't work
  • 11.  RE: ClearPass Eval for CPPM 6.8
    Posted Mar 27, 2019 03:19 AM
    Dear Experts,
    I noticed the Eval License Key for 6.8 in new format (somewhat similar to x509 certificate format) contains a lot of whitespaces. Perhaps this is why copy and paste the license key from email to ClearPass didn't work.
    I managed to get around this by manualy deleting the whitespaces and adding proper line break in notepad.
    Hope this will get fixed soon.
  • 12.  RE: ClearPass Eval for CPPM 6.8
    MVP GURU
    Posted Mar 27, 2019 05:32 AM
    @RobinHulk wrote:
    Dear Experts,
    Get the same issue with mail with licence.. (there is some extra space...)
