Contributor I
ClearPass Guest and Cisco WLC Accounting
Currently running a PoC at a customer site with Clearpass 6.7.5 (new license model). The customer uses a Cisco WLC and we have configured a Captive Portal network with selfregistration (+sponsor confirmation) and Mac-Caching. Everything works pretty well so far!
As far as i know we need accounting to make sure Clearpass knows the concurrent number of Guests.
Unfortunately the accounting does not seem to work well because we see a lot more licenses in use than expected.
Radius Interims Accounting is enabled and we see entries under Monitoring > Live Monitoring > Accounting.
Any hints or ideas what am i missing?
Any known limitations within the setup with a Cisco WLC?
Thanks in advance
best regards
Kevin
Aruba Partner Ambassador | ACMP | ACCX #932
