Re: ClearPass Guest with Meraki Wireless
Are you running ClearPass 6.7 or higher?
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Yes we are running 6.7.9 and I think we finally got it working with the re-authenticate session, audit session ID and increasing the login delay time on the captive portal page.
Thanks for all your great assistance!
Contributor I
Did you get it working with windows 10 laptops as well?
I got it working on smartphones using the reauthentication command and audit-session-id as well. But a laptop just remains connected.
I tried the disconnect as well. Using the Acct-Session-Id and timestamp but nothing seems to work. The laptop just won't disconnect.
