Highlighted
Frequent Contributor I
ClearPass MFA for VIA VPN SSL clients
My client require use MFA with Aruba VIA VPN SSL clients. As I understand there was a perfect support of DUO MFA provider with ClearPass server. I could use DUO server as token server and with ClearPass check user AD logins. Basically it was RADIUS authentication. But after Cisco purchased DUO what other options are possible?
1. Which MFA provider support ClearPass?
2. Where can I find integration guide for supported MFA providers integration with ClearPass?
