Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
Moderator
Re: ClearPass Solution Guide: Wired Policy Enforcement
Version 2018-01 is now available! See original post for details and link.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
Hi Tim, thanks for the update.
We run a number of Aruba 2620 & 2530 switches in our environment and something that bit us when we first implemented ClearPass and 802.1x + MAC Auth through these switches about 1.5 years ago was lack of support for a number of features related to network authentication. For example today, based on the guide, on an Aruba 2530 "ArubaOS" running YB.16.05.0004 there is currently:
  • No downloadable user role support
  • No support for "ip client-tracker"
  • Unless it's changed in the last year and a bit there was also no support for RFC4675 for tagging VLANs on these switches - we had a ticket open with both Aruba & HPE (back in the day) and it was raised as a feature request and the typical response of use a higher model switch as the 2920 supported this at the time. Sorry if this has been added since.
  • i'm sure there's more.
I can certainly appreciate this is an entry level switch and that's not an issue however do you know if there's any Aruba/HPE resource that tables these features that heavily relate to network authentication support specifically? Otherwise it makes reading these guides a little misleading at times unless you know what each switch can and cant do or a minimum model required, etc.
Regards
Jonathan
Highlighted
@cappalli
Future releases to include:
  • Cisco IOS-XE 'Denali' (16.x) with IBNS 2.0
  • Juniper EX
Enjoy
- Aruba Security Team
Just curious if anyone is currently doing this with the Denali code, or if the document for it is close to publication? We are currently testing this out but before I went to TAC I wanted to see if anyone here had it working. We are seeing Clearpass approve devices, but the 3850s are saying the device isn't authenticated.
Thanks!
Highlighted
Moderator
We’re hoping to publish the next release with IOS-XE in April.
Highlighted
Hello there.
Any plan to support the Comware 5 for OnConnect ? Right now it's only comware 7 for H3C/HP Switches.
Everything is working great here with comware 7 switches like 5130, but not so much with older 5120 under Comware 5 (the snmp command to change the vlan for exemple, is not recognize by the switch)
Thx.
(And sorry for my english)
Highlighted
Moderator
Please work with your Aruba account team to raise a feature request for Comware 5.
Highlighted
Re: ClearPass Solutions Guide: Wired Policy Enforcement
Hello Tim
Thanks for creating this document, It's helping a lot.  One thing I do not yet see is this.  I am configuring Aruba 2530 (J9773A) switches for Dot1x raduis based enforcement.  Is there a command on the switch that I can use to fail-open (allow connections) if the switch cannot communicate with the ClearPass server cluster?
Ric
Highlighted
MVP Guru Elite
What firmware do you are using ? with last 16.05, there is this option (don't remenber the name...)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Frequent Contributor I
 Hi Tim,
Before I go into sticking this into lab, I assume the authentication is performed at a port level rather then a client level? My assumption is based on connecting APs to colourless ports and allowing all bridged-wireless authenticated clients access to the transport networks. If not, then I would like to know whether this is capable of working in that scenario?
Any amount of Kudos will be greatly appreciated!!!
Highlighted
Moderator
Authentication is per-MAC.
Colorless ports with User Roles with bridged APs (Instant) is not currently supported.
