ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
  • 1.  ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 19, 2019 05:27 AM
    When creating a Wireless 802.1x GPO with the connection details and information, ClearPass send the authorization to VLAN remediation.
    When creating the WiFi profile manually everything works properly and the right VLAN attached to port.
    (Wireless Profile uses Certificate)
  • 2.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 23, 2019 09:34 AM
    I have not seen differences in settings direct to the OS and through GPO. Please double-check that you are pushing the exact same configuration through GPO as the one that works via local config.
  • 3.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 23, 2019 10:49 AM
    I tried to export the manually created wifi profile via netsh in powershell and import it to the GPO,
    That didnt worked either.
    I opened a TAC ticket and scheduled a remote session with the support and customer,
    hope they can help me solve it.
    Thank you for the reply.
  • 4.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 28, 2019 11:28 AM
    I think some settings is wrong in Wireless profile from GPO.
    Did you try manually settings in wireless profile without GPO?
    For me, it works fine.
  • 5.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 29, 2019 12:19 AM
    Hi
    Yea,
    manually creating the WiFi profile locally is working
    exporting the wifi profile via netsh with powershell then importing to gpo not working or either, creating from scratch the gpo with the exact options i created manually.
    I dont know.
    2 possible issues
    Windows bug
    CPPM configuration
  • 6.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 29, 2019 09:29 PM
    I don't think CPPM issue because it works with local.
    Could you check your GPO wireless profile and make sure that compatible with windows version?
    Did you check Use Windows WLAN AutoConig service for client?
  • 7.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 30, 2019 02:42 AM
    Thank you for the reply and care :)
    WLAN AutoConfig service is running and enabled.
    gpo compatability options when you create a new one is
    *Windows 7 or later
    *Windows XP
    i'm choosing the first option of course and the workstations running WIN 10.
    Thanks again.
  • 8.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Dec 30, 2019 09:43 AM
    Issue resolved,
    Customer had a collision with another gpo.
    Thank you all for the replies and care!
  • 9.  RE: ClearPass-Wireless 802.1x from GPO sends to VLAN remediation
    Posted Jan 01, 2020 09:50 PM
    Good to find the root cause :)
