Highlighted
ClearPass anyconnect + agentless and dissolvable
I have a question that may be you can answer me. In the Onguard integration with the cisco anyconnect VPN client, the type of agent that works and that you have seen in the little documentation that there is is the persistent one, which can do a health check + authentication procedure necessary for the integration, especially For the CoA works, so I wanted to know or confirm that both dissolvable and agentless agents which I know cannot make authentication (only health check) could not work or be used with cisco anyconnect VPN, is that so?
or is there a way?
