Contributor I
ClearPass ipv6 Network Device
Hi folks,
Can I add ipv6 only NAD Device to ClearPass Network Device ?Screen Shot 2018-10-24 at 22.16.43.png
I got this error message if I try to add.
Balazs
Re: ClearPass ipv6 Network Device
ClearPass does not currently support RADIUS over IPv6.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Contributor I
Thanks for your answer Tim!
Balazs
Hi Tim,
Hope you are doing good.
I need help on testing the IPv6 on the clear pass. how can we test the support for Ipv6 over captive portal, CP redirection , web authentication ).
Jagannath
