Highlighted
Contributor I
Clearpass CoA Bounce with ArubaOS Switch - Unsupported Attribute
Hello all,
in order to implement wired guest service, we currently try to initiate a CoA Port Bounce on a HPE Aruba 2930M Stack with WC.16.09.0004 installed. Clearpass is running in Version 6.8.3.110034 on C2000V platform.
Troubleshooting done so far:
- Both CPPM and Switch are running NTP.
- Switchconfig was checked with this guide: http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8152_wb_2920_asg/content/ch06s04.html#s_Configuring_the_switch_to_access_a_RADIUS_server
- Switch is added as NAD with vendor Hewlett-Packard-Enterprise
- Standard-CoA-Port 3799 is used
Switchconfig:
radius-server host X.12 key XXX
radius-server host X.12 dyn-authorization
radius-server host X.12 time-window plus-or-minus-time-window
radius-server host X.12 time-window 0
Screenshots:
Please help, why we are receiving the folling error message when trying to send a CoA:
Radius [ArubaOS Switching - Bounce Switch Port] failed for client 48XXXfXX. Unsupported-Attribute.
Accepted Solutions
Highlighted
Moderator
Re: Clearpass CoA Bounce with ArubaOS Switch
This is a bug in 6.8.3. A hotfix will be released next week to address this issue.
A note was added to the download shortly after it was discovered and it is in the release notes: https://www.arubanetworks.com/techdocs/ClearPass/CP_ReleaseNotes_6.8.3/Default.htm#WhatsNew/KnownThisRls.htm#known_35984
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
View solution in original post
All Replies
Highlighted
MVP Expert
Are you using a VIP in ClearPass?
Please confirm that the time matches between CPPM and the Switch
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
Contributor I
Hello Victor,
thanks for the immediate reply :)
Actually the times match, because both devices are using NTP to synchronize against our AD-Servers.
Here some screenshots:
Highlighted
MVP Expert
Are you a VIP in ClearPass?
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Highlighted
Moderator
Highlighted
Contributor I
Hello Victor,
No - we are not using VIP even though we have a Clearpass-Cluster. This is because we are not L2-Connected between the nodes.
In the switch there are both CPPM-Nodes configured as radius hosts and we do the failover via the switch logic.
We are currently doing some Wireshark and we can see, that CPPM is correctly sending the COA but the switch is returning the CoA-NAK:error11.png
Highlighted
MVP Expert
Tim just indicated that there’s a bug in the version you are running
Thank you
Victor Fabian
