Clearpass Extension installation issues
I've hit a brick wall with a clearpass installation i am working on. I'm attempting to install an extension from the store and i keep receiving the error "Error creating extension instance: store lookup failed"
The funny thing is im able to see what stores are available, so i tried a few different stores and get the same issue. Ive confirmed no proxy is blocking access etc.
has anyone else run into this before? i had a good search through the airheads forum and couldnt find anything relevant
MVP
MVP
Re: Clearpass Extension installation issues
What firmware version do you use? I dont have a lot experience with extententions but in my 6.7.7 deployment i can successfull download the extension.
Also read the release note there is some known issue arround.
"Customers whose networks include addresses in the 172.17.0.0/16 network are advised to either disable the ClearPass Extension service or to contact TAC for assistance in re-allocating the Extensions to use a different network address space. For more information, see #34161."
Another thing thats up my mind but not sure if its relevant to extensions, did you activate de clearpass licenses and add a hpe passport account for download subciption in the CPPM?
Hope this helps you!
Marcel
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Hi Marcel, Thank you for the post. I am looking into the same issue, although i am running CPPM 6.7.8.109113 I am trying to find the installed extension for "Symantec Endpoint Protection Manager" I am getting an error of: "Internal Server Error (500)" and it is not finding the extension, would you know of any other article i can research? Appreciated Gino
MVP
MVP
Hi Gino,
I use CP 6.7.7 and install the named extension without any problems.
Something thats up to my mind:
  • Check the eventviewer for logging
  • Can you download normal updates (is your subsciption and firewall settings ok?)
  • 500 is un internal server error, try remove browser cache or try another browser?
Did you already find this document? ClearPass_Integration-Guide_Symantec-Endpoint-Protection-Manager_v2018-01, link.
