Highlighted
Frequent Contributor I
Clearpass Guest Manage Devices remove print icon
I used this topic to remove the print options in an operator profile
https://community.arubanetworks.com/t5/Security/How-to-remove-the-print-option-from-operators/td-p/226731
by adding
<div>
<form name="print_templates_form" style="display: none">
</form>
</div>
in the footer of the form and the list views  the operator profile is using but it does not remove the print icon when you select a device in  Manage Device view
Inspect shows the item to be in the mac_list_action_row_print form but adding
<form name="mac_list_action_row_print" style="display: none">
</form>
to the footer of the mac_list view does not work
These forms and views are used for MPSK zo there's no need for printing receipts.
Can anyone help out?
thanks
Erik
ACMX#1245, ACDX#968, ACCP, ACSP
Accepted Solutions
Highlighted
Re: Clearpass Guest Manage Devices remove print icon
Each of those actions has a common ID selector.
Add this into the Header HTML or Footer HTML of mac_list and/or guest_users Views.
{literal}<style type="text/css">
#guest_users_action_row_print, #mac_list_action_row_print {
display:none;
</style>{/literal}
View solution in original post
All Replies
Highlighted
I don't see an easy way to remove/hide the print option since the mac_list form is not exposed in the UI.
You may try removing permission to the operator under each print templates. This will not remove/hide the print option, just don't show print templates selection when you click on it (in a way prevent print option).
Thank you,
Saravanan
**Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the post.
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
display:none;
</style>{/literal}
Highlighted
thanks for that. Just what I was looking for.
Most of them are linked to rights in the operator profile but would like to know if there is a list of common ID's available for the different icons?
thanks,
Erik
Highlighted
If you right-click and Inspect, which I think most browsers have now, you can see them.  The ID follow:
'#' + view name + '_action_row_' + ACTION
Where ACTION is one of:
Devices:
  • change_expiration
  • remove
  • edit
  • sessions
  • print
  • details
Guest extras:
  • reset_password
